Cbernad's avatar
Cbernad
Orbi RBK50 WiFi gone wonky
Been working like a dream for quite awhile. Now the WiFi is all jacked up, but wired LAN works perfect. On wifi:
- I can use iMessage
- cannot access webpages or speedtest.net
- cannot access routers through Genie
- tried rebooting, complete factory reset, nothing fixes it
Any thoughts out there?
Cameron
  • FURRYe38's avatar
    What FW is currently loaded?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    What WPA security modes are you using? Try WPA2 and AES only.
    IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Disney Circle: https://community.netgear.com/t5/Orbi/WARNING-Firmware-2-2-1-210-is-junk/m-p/1667485/highlight/true#M45926
    Be sure the BeamForming and MIMO are enabled.
    • Cbernad's avatar
      Cbernad
      The FW is the most current.  But I have some new information.
      The WiFi connectivity issues seem to be somewhat device specific.  Most of the devices are now accessing the internet, but I have one iPhone, one iPad, and a couple of Kindle Fires that are not.  Although they show that they are connected to the network, when I go into Genie those devices are not showing up.
      • FURRYe38's avatar
        Please let us know if any of the suggestions help.
        Please give feed back to the question presented so we can get a better idea of your configurations.
