rjdennison
Dec 04, 2018Aspirant
ORBI RBK50 worked for 2hrs, now dead
This is so frustrating... Paying as much as I did for this kit, and it's far far worse than what we had. I set this up last night. Everything seemed to be going well... got the satellite connected,...
- Dec 21, 2018
Update:
They RMA'd the router, and when the new one arrived, it worked fine. It's now autoupdated to the new firmware, and it still going strong.
Looks like I had a bad piece of hardware.
Thanks for the help everyone!
R.
Dec 04, 2018Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
After doing the reset, connect a wired PC to the base router and use a web browser to walk thru the setup wizard at 192.168.1.1.
- ekhalilDec 04, 2018MasterWhat wired devices do you have connected to Orbi? Do you have any wired mesh devices (e.g Sonos speakers)?
- rjdennisonDec 04, 2018Aspirant
The ORBI is plugged into another router at this point. It's not the upstream connection I'm having trouble with. The router is up and down all the time now.
Is the Orbi system operating in Router or AP mode?I've flashed the 2.1.4.16 firmware onto both the satellite and the router, and forced the router to not autoupdate. It's operating as its own router, although I plan to use it as an AP and turn off the other router's wifi when the ORBI is reliable enough to do so.
What is the size of your home? Sq Ft?5,000 including the basement, but the router is on the main floor at one end of the house, and the satellite is on the 2nd floor around the middle of the house.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.Probably a bit more than that, but when the system is working, the satellite reports a "good" connection with the router.
I haven't changed the channels at all, so I would assume auto
Any Wifi Neighbors near by? If so, how many?There are wifi neighbors near by. We are on a single family home cul-de-sac, so it's not terribly dense, but there are neighbors to be sure.
What WPA security modes are you using?WPA2 Personal AES
I'm now on a laptop connected to the router via ethernet, and can hit the router at 192.168.1.1
- FURRYe38Dec 04, 2018Guru - Experienced UserWhat is the Mfr and model# of the ISP modem the NG router is connected too? So is the Orbi working now?
- rjdennisonDec 04, 2018AspirantSorry - I put this in the prev reply, but didn’t change the color of that text.
It’s plugged into another router that is running TomatoUSB. My intention is to use the Orbi as an AP with the Tomato router doing all the “router” stuff.
The Orbi router is working if I’m plugged into it. The wifi, however, doesn’t work. The wifi is kind of the point ;)
Thanks for all your help on this FURRYe38
