rjdennison
Dec 04, 2018Aspirant
ORBI RBK50 worked for 2hrs, now dead
This is so frustrating... Paying as much as I did for this kit, and it's far far worse than what we had. I set this up last night. Everything seemed to be going well... got the satellite connected,...
- Dec 21, 2018
Update:
They RMA'd the router, and when the new one arrived, it worked fine. It's now autoupdated to the new firmware, and it still going strong.
Looks like I had a bad piece of hardware.
Thanks for the help everyone!
R.
Dec 05, 2018Guru - Experienced User
So how is the wifi not working?
Do you get any wifi from the base router while in AP mode?
Besure ALL other wifi sources are disabled on the Host router and other devices you may have.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
rjdennison wrote:
Sorry - I put this in the prev reply, but didn’t change the color of that text.
It’s plugged into another router that is running TomatoUSB. My intention is to use the Orbi as an AP with the Tomato router doing all the “router” stuff.
The Orbi router is working if I’m plugged into it. The wifi, however, doesn’t work. The wifi is kind of the point ;)
Thanks for all your help on this FURRYe38
rjdennison
Dec 05, 2018Aspirant
Yeah, I guess I didn't explain that very well. So it seems that the wifi SSID is there, but when I connect to it from any device, there is no internet. Strength seems fine, but the wifi won't pick up an IP address (can't contact DHCP server). Recall I've got this set up as a router right now, so it's the router's DHCP server that either isn't responding or doesn't hear anybody asking for an IP address.
I haven't tried AP mode since rolling back to 2.1.4.16. I figure I should get the "default" configuration working before I get fancy.
I'm going to try that next. I haven't experienced any strength issues, but I don't know much about mesh, so I guess it's conceivable that the interference is causing all the problems.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
I've rolled back from v.210 to v2.1.4.16, but I'll try all those things above that you suggested. I'll try shutting down all the other wireless networks first, see if that changes anything, then start shutting down those services one by one.
Thanks again FURRYe38 . Going to try all this stuff on Friday morning.
R.
- FURRYe38Dec 06, 2018Guru - Experienced User
Ok, let us know how it goes. Either mode should work well. If you don't think the system is working in either mode like it should. I would contact NG support and ask for an RMA.
- rjdennisonDec 07, 2018Aspirant
Ok here's the state:
- Firmware v2.1.4.16 on both RBR50 and RBS50
- all other sources of wifi are off.
- I am connected to the RBR50 via ethernet, and can access the web interface and internet
- No wireless clients can connect to the orbi network.
- the SSID is there
- it connects for a second, then shows "no internet access" (recall a wired connection to the router has internet, so the router is connected to the internet). Evenually clients just drop the wifi connection.
Trying some of the adjustments you mention:
Disable MIMO, Daisy Chain, Fast Roaming... no change... still no internet connection on wireless clients and eventually drop the wifi
Turn off 20/40MHz coexistence... got it to stay on wifi for a few seconds, and it looked like I actually had a connection (although only 80Mbps vs. the 180Mbps I was seeing when I first hooked the Orbi up), but that went away in less than a minute. I watch wifi clients just sitting there trying to connect to the Orbi network, then drop, then try to connect, then drop....
Rebooted router (after trying 20/40 coexistence)..
Ok - NOW things are cooking... > 300Mbps on Orbi wifi.
I'm going to leave this for a bit to see how stable it is. After I determine it's stable, I will try turning things on (except that 20/40 coexistence thing) one by one to see if anything breaks it.
Spoke too soon... 1 minute later, the wifi has dropped and the clients say "no internet connection"...
So clearly this thing cooks on a fresh reboot, but the wifi problem is not being solved. Not even sure if it's the 20/40 coexistence thing that solved it... might just be on the reboot.
Spent the last hour on telephone support to no avail. I should hear back from them after she takes the issue to L2.
Might be that I have a dud here ><
