Walkingbear
Jun 10, 2020Aspirant
Orbi RBK50
Question, does the orbi RBK50-100NAS work with a DSL internet service like say Centurylink.?
- WalkingbearAspirant
Ok, found my answer on page 14 of the manual.
Thanks
Question is that if Orbi works with the modem. There are two types, modem only and modems with built in routers and wifi:
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopOrbi systems work with most ISP services and modems or ONTs.
