Xx-Shadowz-xX
May 11, 2022Aspirant
ORBI RBK50v2 BEST WAY TO SETUP?
What is the best way to setup the ORBI RBK50v2 after doing a factory reset? Setup by connecting to PC or Setup by using the ORBI App from Apple Store using IPhone?
KevinLiT
May 11, 2022NETGEAR Moderator
Hello Xx-Shadowz-xX,
In my experience, the best way to set up a new Orbi system is by using the Orbi App. The walkthrough guidance allows you to customize your network. Therefore, once you are done with the setup process your network is ready to go.
Using the Web GUI is preferable when you know exactly where to go to manipulate the settings desired for your network.
Cheers!
Kevin
Community Team
