richc9990
Dec 27, 2018Guide
orbi RbK53 - Connection not private
I have asked about this already on amazon and was referred back to here.
I have purchased the ORBI RBK53 AC3000 tri band home mesh. I have installed the units and found both satelites. The Or...
- Dec 27, 2018
You may look into this:
https://community.netgear.com/t5/Orbi/Orbi-Blocking-Websites-Solved/td-p/1677125
Dec 27, 2018Guru - Experienced User
What FW is currently loaded?
I have purchased the ORBI RBK53 AC3000 tri band home mesh. I have installed the units and found both satelites. The Orbi is giving good speeds and is stable.
The problem I'm having is with any browser on any device pc/Android/Apple/iphone etc. many urls are saying "this connection is not private". this only happens when passing through the orbi. Connecting via the modem the same pc/same url are fine.
I have found I can add https::/url and access the site. but searches have suggested my date needs updating. (on each machine which can't be relevant).
So what can I do to remedy this please.?
richc9990
Dec 27, 2018Guide
Hi,
Firstly thanks for the HTTPS solution. worked a treat.
FW is 2.2.1.210
the modem is an EE smarthub
Firmware version:
v0.00.24.06190-EE
Firmware updated:
15-Nov-2018
Serial number:
+EEH001+
One more simple question, Can i get an indicator light on the router and satelites so I know they're on and working by sight?
Many thanks
