outpostuk
Jan 02, 2018Aspirant
Orbi RBK53 + Virgin Superhub 3 setup steps
Hi, I'm new to the community. I have just purchased the Orbi RBK53 system, and hope to use it with Virgin Media Cable, that I am have installed in a couple of weeks. It will come with the Suprhub 3...
masonworld
Jan 02, 2018Apprentice
I don't have a SuperHub3, but I am almost certain that you will have to make changes to the SH3 config manually -- Orbi will not adjust SH3 config automatically. As you suggest, you will want to put the SH3 into modem mode and turn SH3 WiFi off.
Note that the stability of the current version of Orbi firmware is in question -- hopefully there will be new FW out there before you go live.
- outpostukJan 02, 2018Aspirant
masonworld. Hi thanks for the info. Will look into this option further.
