outpostuk
Jan 02, 2018Aspirant
Orbi RBK53 + Virgin Superhub 3 setup steps
Hi, I'm new to the community. I have just purchased the Orbi RBK53 system, and hope to use it with Virgin Media Cable, that I am have installed in a couple of weeks. It will come with the Suprhub 3...
outpostuk
Hi Andrew,
Thanks for the options .... I'll look into them further. Have an installation date in a couple of weeks, so have time to investigate.
I believe the second option is similar to how my current set up is; BT Home Hub, with BT Whole Home Wifi.
outpostuk
Jan 03, 2018Aspirant
Hi, just an update. I decided to test my Orbi by setting it up with my current BT Infinity Network. Went through the setup process, but couldn't get conneted to the internet. Decided to give the Orbi App a go, and set it up again through that, and it worked. All lights went out, and speed was 59mbps (which is normal). Going to try to use this to see if I can update the firmware at the weekend.
