larryindublin
Jan 12, 2018Luminary
ORBI RBK53 2.1.2.10 firmware actually seems stable for me
So I just checked and my Router has now been up for 5 days. Satellite for just over 3 days, but I relocated it 3 days ago. I have a 2 satellite kit, but have removed 1 satellite from my setup since I...
WAS_1
Jan 13, 2018Aspirant
Just upgraded to V2.1.2.10 Beta. All ok except that one Satellite now has Backhaul Status: Poor; the other Satellite is Good. Previously, both were Good. Will adjust the position of Satellite 1 to see if I can restore to Good. Otherwise, all is working ok.
- Miles267Jan 13, 2018Apprentice
WAS_1 wrote:Just upgraded to V2.1.2.10 Beta. All ok except that one Satellite now has Backhaul Status: Poor; the other Satellite is Good. Previously, both were Good. Will adjust the position of Satellite 1 to see if I can restore to Good. Otherwise, all is working ok.
Am experiencing same behavior with 2.1.2.10 and one of my satellites. In this case it's one of the new Outdoor satellite units. Were you able to address your issue?
BTW, I have daisy chain disabled.
- WAS_1Jan 13, 2018Aspirant
Yes, I re-installed the Beta firmware on that satellite, and now the Backhaul status on both Satellites is Good. I also have Daisy chain disabled.
- larryindublinJan 13, 2018Luminary
Odd thing with my satellites (and not just on this beta firmware) is that it sometimes takes a few minutes for the to “settle in”. The connection and strength will bounce around for a bit.
