ZoneMaster
Apr 29, 2018Apprentice
ORBI RBK53 (AC3000) "No AirPrint Printers Found" After Firmware V2.1.4.10 Installed
Have been running my ORBI RBK53 system for almost a year. AirPrint from multiple iOS devices (1x iOS 9.3.5 & 3x iOS 11.3.1) worked flawlessly until a few days ago. The only thing that changed was the...
- May 02, 2018
I have been running the 2.1.4.10 firmware since last week. Network scan via "Net Analyser" iOS app showed NO Bonjour flags present
I have performed the following additional toubleshooting from my iMac (which is fairly distant from my Comcast/ORBI gateways):
- Connect ONLY via my Comcast Wifi Modem:
- Powered off ALL ORBI units:
- Turned on WiFi on my Comcast Router
- Logged in to my Comcast WiFi
- Weak signal & slow upload/download speeds
- mDNS/Bonjour/AirPrint was rock solid
- Network scan via "Net Analyser" iOS app shows Bonjour flags are present
- Connect ONLY via ORBI RBK53:
- Turned off WiFi on my Comcast Router
- Powered on ORBI RBR50 Router
- Logged into ORBI WiFi
- Better signal & faster (but not max) upload/download speeds
- mDNS/Bonjour/AirPrint working. Network scan via "Net Analyser" iOS app shows:
- macOS & iOS seem to reliantly report Bonjour as present
- AirPrint printers (HP & Brother) sometimes don't report Bonjour as present
- Waited
- Powered on ORBI RBS50 Satelite closest to my iMac
- Max signal & max upload/download speeds
- Waited
- Powered on final ORBI RBS50 Satelite
- Everything working
- Waited
While mDNS/Bonjour/AirPrint is still sometimes glitchy. It is working under the 2.1.4.10 firmware after starting the router & satellites in slow sequence.
ZoneMaster
May 02, 2018Apprentice
- Waited
- Waited
- Waited
- altern8May 02, 2018Aspirant
i have a rbk20 and this issue popped up after upgrade from 2.0 to 2.1.4.10. I ended up disabling MUMO, Fast Roaming and Beam Forming to fix the AirPrint issue. I don't know if all or just one option is the cause but I have no patience at this time to further troubleshoot.
- ZoneMasterMay 04, 2018Apprentice
BTW: NG's "90 day & then you pay" support is terrible! Heck, Apple (which so many love to compain about) still lets you contact them after 90 days & has a knowledge base for questions & error reports. NG has a paywall & community support!
