dscott77
May 02, 2018Aspirant
Orbi RBK53 and Comcast XB3 Set-Up -- It's Finally Working but is It Correct?
Yesterday I replaced my aging Apple Airport Base Station (and Time Capsule) with an Orbi RBK53 (router and two satellites) from Costco. My ISP is Comcast via an XB3. Powering up and placing the Orbis...
dscott77
Have been trying on FF but will attempt with Safari.
dscott77
I cleared the browser cache. Safari and Opera (IE 11 is not longer available for Mac.), result is the same. The "Router/AP Mode" page comes up and shows "AP Mode" is selected. Hitting "Apply" again takes me through the same route I've described and I always come back to the starting page. Both Comcast and Orbi continue to appear in the drop down list as options on an computer or device I check. IE 11 is not longer available for Mac. I guess my only choices are to keep everything as is until I decide to change course and Bridge the Comcast and re-set-up the Orbi to be the router.
- FURRYe38May 02, 2018Guru - Experienced User
Does the process take you to the end of the set up wizard? Seems like the setup wizard hasn't fully completed. Ya, you might try a reset on the router and walk the set up wizard to it's completion.
- dscott77May 02, 2018Aspirant
The process I'm using is accessed via orbilogin.com, signing in and navigating to "advanced," then, "advanced set-up," then "Router/AP Mode" as instructed by https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
Don't know if that's the same as the "Set-Up Wizard." I've tried my IOS Orbi app to see if it might tell me whether or not AP has been enabled but it's silent on the matter.
