HCC202
Mar 24, 2018Star
Orbi RBK53 Correct Firmware
I have a RBK53with two satelites. I am presently running firmware V2.1.2.18. When I go on the website it says current firmware is V2.0.1.14. When I went to manually update the firmware to V2.0.1.14 i...
Mar 24, 2018Guru - Experienced User
v.18 was pulled from automatic updates due to users complaining about it. NG recommended v.14 as the most current. If your not seeing any issues then keep whats loaded. If you are then try downgrading to v.14
HCC202
Mar 25, 2018Star
I have a Arris 6190. I keep dropping internet,but Orbi shows the wifi is up but no internet. The Arris is brand new and and had the same problem with the old modem. I have had comcast out and they have checked everything several times. Not sure what the issue is. Any suggestions?
Thanks
- DarrenMMar 28, 2018Sr. NETGEAR Moderator
You may want to try the beta firmware and see if that helps with your connection issues.
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/td-p/1533584
DarrenM
- HCC202Apr 09, 2018Star
I did a factory reset and loaded the new firmware. The system seems more stable, but i did have to do a reboot once in the last two weeks.
- FURRYe38Apr 09, 2018Guru - Experienced User
Good to hear. Glad its working better. Eventually, resets shouldn't be need.
I would make a save configuration to file for this version of FW for safe keeping.
Enjoy.
- FURRYe38Mar 28, 2018Guru - Experienced User
Yes, pleaes try the Beta version of FW.
Also be aware of your ISP modem SB6190:
Let us know how the Beta works for you. Please perform a full factory reset on both router and satellites then set up from scratch.
HCC202wrote:I have a Arris 6190. I keep dropping internet,but Orbi shows the wifi is up but no internet. The Arris is brand new and and had the same problem with the old modem. I have had comcast out and they have checked everything several times. Not sure what the issue is. Any suggestions?
Thanks
- HCC202Mar 29, 2018Star
I will make the changes this weekend and see how if it helps. Thank you
- FURRYe38Mar 29, 2018Guru - Experienced User
:smileywink:
