HCC202
Mar 24, 2018Star
Orbi RBK53 Correct Firmware
I have a RBK53with two satelites. I am presently running firmware V2.1.2.18. When I go on the website it says current firmware is V2.0.1.14. When I went to manually update the firmware to V2.0.1.14 i...
HCC202
Mar 25, 2018Star
I have a Arris 6190. I keep dropping internet,but Orbi shows the wifi is up but no internet. The Arris is brand new and and had the same problem with the old modem. I have had comcast out and they have checked everything several times. Not sure what the issue is. Any suggestions?
Thanks
DarrenM
Mar 28, 2018Sr. NETGEAR Moderator
You may want to try the beta firmware and see if that helps with your connection issues.
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/td-p/1533584
DarrenM
- HCC202Apr 09, 2018Star
I did a factory reset and loaded the new firmware. The system seems more stable, but i did have to do a reboot once in the last two weeks.
- FURRYe38Apr 09, 2018Guru - Experienced User
Good to hear. Glad its working better. Eventually, resets shouldn't be need.
I would make a save configuration to file for this version of FW for safe keeping.
Enjoy.
- Retired_MemberApr 09, 2018
so where at we at with a prime time FW release that auto update will reflect?
