mohammed997
Sep 27, 2020Aspirant
Orbi RBK53 internet connection is not stable
Hello
My RBK53 orbi is facing internet unstability issue. usuaaly during the day it disconeectets three to four times. The issue is the main main router that the orbi devices is connected with has no internet stability issues.
This issue just appeared recently. I tried to solve it by updating the frame to the version 2.7.0.70 and it did not solves the problem. Then, I tried version 2.5.2.4 it reduced the number of times it gets dissconnected, But the issue is still bothering me.
My internet peed is 100Mb/s and I live in Saudi Arabia
1 Reply
Built in router here by chancr? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopHas a power OFF of the ISP modem, RBR and RBS for 30 seconds since last FW update been performed?
