onearmsykes
Jul 23, 2017Follower
ORBI RBK53 Novice
Have owned the RBK53 for several months and just started having issues after a power outage 7/14. The issues comprise of all devices picking up the WIFI signal however only some of the devices ca...
cyberprashant
Jul 23, 2017Luminary
https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/td-p/1320421 - check this thread if it sounds like you (dropping off / on of wifi after most recent 1.12.0.18 Fw. If so downgrade as per page 5 of the thread if you are able to. I have RBK53 from costco and was affected.
