- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Firmware V1.12.0.18 Discussion
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
This does indeed appear to be based on (identical to?) the last private beta V1.12.0.16 and has been released to the public. Hope it helps!
Guest mode AP isolation finally works 100% over IPv4 and IPv6 - much happiness in my household. 😃
Rodney
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
New Features and Enhancements:
- Supports ReadySHARE Printer for Orbi devices that are equipped with a USB port
- Updated the OrbiOS API to v3.14
Bug Fixes:
- Fixes the iOS disconnection issue.
- Fixes the Dropcam disconnection issue.
- Fixes the convergence issue when an Ethernet connected device moves from one Orbi to another.
- Fixes the issue where the Orbi app can’t find the Orbi router if the router is using IPv6 and is in AP mode.
- Fixes the issue where the Orbi app can’t display more than 20 connected devices.
- Fixes the issue where the installation assistant might not display if the device is connected to the Orbi network wirelessly.
- Fixes the issue where the 2.4 GHz backhaul setting is disabled if the fronthaul MU-MIMO and TxBF is disabled.
- Fixes the issue where IPv6 devices on the guest network can access the Orbi router’s web GUI.
- Includes security fixes for the following security vulnerabilities:
PSV-2016-0133, PSV-2017-0607, PSV-2017-0615, PSV-2017-0736, PSV-2017-2190
Download Link:
RBR50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBR50-V1.12.0.18.zip
RBS50 - http://www.downloads.netgear.com/files/GDC/RBK50/RBS50-V1.12.0.18.zip
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: V1.12.0.18 is out
I'm wondering what gonna change for people with already problem free Orbi setups. Hope it won't make it worse 🙂
We have three different generations iOS devices and no disconnects. Well, we'll see soon enough 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I've been problem free, as far as I know, and this update just went in smoothly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
So far so good for me as well.
- Update went smooth
- Speeds are looking good
- Wifi calls working much better (only 20 minutes test so far
Here's hoping this is the release that brings us stability again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I completed online update of 1.12.0.18
But now I cant tell if my SAT updated.?
Do I need to do a manual update on SAT? It shows CURRENT Version, but Update Failed ERROR
Orbi Wifi 6 and SAT
OS: Win10 | 36 connected devices | Router and Sat. about 50 ft a part. (two walls)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Does NETGEAR provide a list of bug fixes or enhancements file with their updates?
Orbi Wifi 6 and SAT
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I found where release notes are posted. 1.12.0.18 arent there yet... I will check back later.
Orbi Wifi 6 and SAT
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Bug Fixes:
Download Link:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
That is from the HTML release note that comes with the manual download
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Still good news. Had multiple Skype calls and walked around to force multiple switches from router to satellite, not one dropped call.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Support helped correct my FW update error... I did a manual update for the SAT to get the information from the upate page to match.
Orbi Wifi 6 and SAT
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
3 hours on new FW 1.12.0.18 - Solid number on all devices thus far.... Comcast ...fingers crossed 🙂
Happy DAY.... Same speeds at SAT
Orbi Wifi 6 and SAT
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I hope this is the fix needed. I'm and going to end my eBay auction early on my Orbi and give it one last shot. This is the first time I have seen support email a firmware and post it to the message boards with such confidence.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Yes... I have both checked active.
Orbi Wifi 6 and SAT
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You may want to try a factory reset before loading new firmware.
Orbi Wifi 6 and SAT
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I can't wait to load this after I get home from work. I would have been pissed if I sold my Orbi on eBay and missed an opportunity to test the firmware out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I am still in my Return window. I am buying a 2 year protection plan from BBY for $38.. if it doesnt hold up I have options.
Orbi Wifi 6 and SAT
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have not turned on implicit beamforming yet as I thought that was only needed for older devices and the default beamforming was better. I do have MU-MIMO turned on. All is still working perfectly.
Now if only I could purchase a satellite.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Has anyone tried this new firmware with the Orbi in AP mode? If so did you disable the wireless on your router and let the Orbi handle the wireless connections in AP mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Yes, indeed, late last night, we pushed out OrbiOS 1.12.0.18 in response to reports of wireless disconnects, including those with Nestcam / Dropcam, Macbook Pro that have been affecting some users. Over the last few weeks, we’ve taken concrete steps to investigate & address them, including running a comprehensive beta program. Over the next few days, your Orbi will automatically download this firmware and upgrade itself. If you want to manually upgrade, feel free to perform a manual upgrade through orbilogin.net).
We’d like to thank our beta users and Community for helping us through this, and those of you running the beta release (1.11.0.8 or earlier versions of 1.12) should upgrade to this new release.
In addition, in this release, for those customers who have an Orbi with a USB port (RBK50 or RBK53), we’re enabling the USB ports for uses like attaching a printer. This has been a widely requested feature request from the community and we’re happy to deliver.
Orbi Product Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
So it appears that the ability to disable either 2.4GHz or 5GHz has been removed even though it was already available. In my situation, the 5GHz band outperforms the 2.4GHz everywhere on my property so I disabled the 2.4GHz band. It was causing my devices to be "stuck" on 2.4 channels half the time due to the forced band steering. Even with this new update I am getting the same behavior. This is quite upsetting as now I have to connect and disconnect several times before my devices are on 5GHz. I have tried waiting, and it does not switch correctly 50% of the time. By all means, keep both bands enabled by default. But give back the option to disable them in the advanced settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
1.12.0.18 is as solid as 1.12.0.16 for me, and my problems with the 1.11.x versions remain fixed for me. No disconnects, all sats showing in the web UI, 90+ devices. Nice work Netgear!
