ShankarHokie
Feb 22, 2020Apprentice
Orbi RBK53 system: Should I wire new home for ethernet ??
I have an Orbi RBK53s system with an RBR50 router & 2 RBS50 satellites. They are mated to an Arris SB8200 modem for the Xfinity 600Mbps plan.
The satellites are paired to the router wirelessly.
We are building a new home. The bulider is wiring the home with Cat6 cables and terminates them on the kitchen ceiling & upstairs bedroom ceiling for optional wireless access points (extra $$). In that setup, the modem & router can be placed in the basement and the wiress access points provide coverage in the 1st & second floor.
Since I already have this Orbi system, I'm not going to opt for their access points.
If I want to keep the modem & router in the basement and I want to use one staellite in the fisrt floor and one in the second floor, can I do that wirelessly? Otherwise, should I ask them to provide me network drops in the first floor and second floor to connect the satellites with ethernet cables? Is this what is called ethernet backhaul?
Home is about 2800 sq.ft
Are there any advantages with this wired connection? Speed? stability?
Thanks !
- tomschmidtVirtuoso
A wired backhaul will be more stable and faster than the wireless backhaul. I recommend CAT7 cable for the current best network cable. If possible, it could be in conduit to be replaced easily with future upgrades, but that of course would be more expense.
Oh, my. YES. If the walls are open, have Cat6 cable pulled to anyplace you might consider locating electronics (TV's, computers, security cameras, WiFi access points). I, personally, would skip the ceilings. A home is not like a hospital or office building where people think nothing of ugly devices attached to the ceilings.
Wired connections are ALWAYS superior to wireless. They are more stable, faster, and more secure. Once the walls are closed up, you will regret not installing ethernet cables when you had the chance.
Also, the "hub" where these cables all come together needs to have space to mount the patch panel, an ethernet switch, and the router, plus electrical outlets to support them. And, it can't be a sealed closet with no ventilation.
- ShankarHokieApprentice
Thanks. I am going to be forceful not to have it on the ceiling. It looks ugly, especially if I'm not going to use it.
I would like to understand this comment:
"Also, the "hub" where these cables all come together needs to have space to mount the patch panel, an ethernet switch, and the router, plus electrical outlets to support them. And, it can't be a sealed closet with no ventilation"I expect this modem & the RBR50 router will be in the basement in an open area. I plan to have 3 cat6 runs to 3 spots in the house. Those will plug into the back of the RBR50 in the basement and terminate in these 3 spots for connecting my RBS50 satellites.
Will I still need a patch panel & a ethernet switch?
