mf26uk's avatar
mf26uk
Orbi RBK53 United Kingdom compatibility
Hi there. I live in the U.K. and considering buying the Orbi RBK53 from the US but wondering if the voltage of the unit for sale there is designed to be compatible only for the voltage/power supply in the US. Also, are the supplied power cables/plugs only useable in the US? Thank you
  • Just to clarify, the US Orbi power adapter will work for all regions, including the UK.  However, you'll need to get a separate wall plug or outlet adapter specific to UK.
    From Orbi user manual.
    Power adapter:
    • North America: 120V, 60 Hz, input
    • UK, Australia: 240V, 50 Hz, input
    • Europe: 230V, 50 Hz, input
     All regions (output): 12V, 3.5A DC output
    You need to get an adapter for UK.
    • SW_'s avatar
      SW_
      Prodigy
  • FURRYe38's avatar
    Pease post in the main Orbi forum next time for your model Orbi:
    https://community.netgear.com/t5/Orbi/bd-p/Orbi
    Good Luck.
