JonSina72
Nov 27, 2018Aspirant
ORBI RBK53
I have the rbk53 but my problem is that the phone line is by the front door, hence as far as I can workout the router has to go there.
The 2 satellites are split - one in the middle of the hous...
Nov 27, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. This would enable satellite to satellite connection, however they need to be in a linear line out from the main base router. Like a chain of christmas lights.
The R8000 can't be used in the MESH system.
JonSina72
Hi FURRYe38,
thanks for for your help, I’ll give the daisy chain a go.
My router is a Sky Hub router (the one that comes with Sky Q - there is no obvious rebrand on it)
theres approximately 30 feet between the router and satellite 1 and then 30 feet between sat 1 and sat 2 with a 2 or 3 walls in between on both.
2.4 is on auto, and 5 is set to 40. I’ll have a fiddle with your suggestions and see what happens.
Cheers,
Jon
