JonSina72
Nov 27, 2018Aspirant
ORBI RBK53
 I have the rbk53 but my problem is that the phone line is by the front door, hence as far as I can workout the router has to go there.
 The 2 satellites are split - one in the middle of the hous...
JonSina72
Hi FURRYe38,
thanks for for your help, I’ll give the daisy chain a go.
My router is a Sky Hub router (the one that comes with Sky Q - there is no obvious rebrand on it)
theres approximately 30 feet between the router and satellite 1 and then 30 feet between sat 1 and sat 2 with a 2 or 3 walls in between on both.
2.4 is on auto, and 5 is set to 40. I’ll have a fiddle with your suggestions and see what happens.
Cheers,
Jon
Nov 27, 2018Guru - Experienced User
JonSina72 wrote:
Hi FURRYe38,
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Cheers,
Jon
