badlands
Jan 09, 2026Follower
ORBI RBR 20 Speed
I just upgraded my home broadband. The download speed directly from the cable co model is 1107 Mbps and upload 34.2. when I test through the ORBI RBR 20 the download speed is 550 Mbps and upload 1...
Jan 09, 2026Guru - Experienced User
Yes. Wou'll not see much over 500Gb over wireless. Wired you should see near 900Mpbs. The 20 series is older generation so if you want to see over 900Mpbs, may want to upgrade to newer generation Orbi system
