badlands
Jan 09, 2026Follower
ORBI RBR 20 Speed
I just upgraded my home broadband. The download speed directly from the cable co model is 1107 Mbps and upload 34.2. when I test through the ORBI RBR 20 the download speed is 550 Mbps and upload 1...
Jan 10, 2026Guru - Experienced User
If you're testing wired, you should be able to get a bit more speed. Wireless, thats about all the device has.
- what modem are you using?
- ARE you testing wireless?
- Disable any parental controls, access controls, traffic monitoring, or qos on these device. They do traffic inspection and can slow the speeds on these devices.
