Mfrostjones
May 01, 2018Guide
ORBI RBR 50 can not get it to work...
I have spent the last 2 hours trying to set up my Orbi router & satellite. I am able to get as far white light, then I log in to the orbi wifi successfully then trying detect, it get 1/4 the way then...
st_shaw
May 01, 2018Master
Mfrostjones wrote:
I’m still connected via WiFi and my internet works as I do speed tests and all is good. I have xfinity and can log into orbi’s WiFi.
So, what exactly is the problem then? I cannot tell from your descripton nor from your image.
Mfrostjones
May 06, 2018Guide
I am unable to connect to my orbi. I get stuck and then brings me back to this page. I can not link it up.
- UlairiMay 06, 2018Luminary
Have you tried setting it up using the browser from a PC, rather than the App?
- DarrenMMay 08, 2018Sr. NETGEAR Moderator
There was issue in 2.1.3 with setup using the app are you able to try and set the unit up with a web browser using orbilogin.net?
DarrenM
- MfrostjonesMay 08, 2018Guide
I will try
- MfrostjonesMay 09, 2018GuideI have tried to do it through my computer and it’s Not finding the internet connection. It’s stating I need to reboot the modem (again) and to check the Ethernet connection.
Help!
