dbeelaert
Apr 13, 2020Aspirant
Orbi RBR 50 has problems with my new ATT Fiber gateway
Hello Techy People, I could really use your help! I am NOT a technical user but I need some help in fixing a problem. My "help support" that was free through Orbi expired 10 days ago, and I real...
- Apr 13, 2020
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router and wifi here? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI recommend trying option #3 first. Contact your ISP for help and information about the ISP gateway.
Apr 13, 2020Guru - Experienced User
Yes that a modem gateway router.
Simplest method would be AP mode on the Orbi system:
Disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://www.f0il.com/how-to-arris-bgw210-700-modem-router-with-netgear-xr500-router/
https://community.netgear.com/t5/Orbi/How-do-I-setup-bridge-mode-in-the-ARRIS-BGW210-700/m-p/1875994/highlight/true#M84982
ATT Dumb Swiith Method:
https://community.netgear.com/t5/Orbi-AX/Orbi-AX-6000-and-AT-amp-T-fiber-gateway-issue/m-p/1890125/highlight/true#M2756
dbeelaert wrote:Wow, you are amazing!
I don't know all the details, but YES it's a modem and WiFi router combo.
I've attached a picture of the back of the modem...does this make sense to you?
dbeelaert
Thank you so much!!
Okay...it looks like there are several plans to help remedy the situation. Thank goodness! Per the links that you have attached to your reply. Which do you recommend I start with first?
I really do appreciate everyone's help!!!
Dina
