Adrianbrazen's avatar
Adrianbrazen
Follower
Dec 03, 2021
Orbi rbr 50 reboots everyday
everyday since i have updated to Firmware Version 2.7.3.22 my router reboots every morning around 9:00 AM. When I check the logs the below message is what I see:
[Initialized, firmware version: V2.1.4.16] Friday, December 03, 2021 09:26:23
can anyone assist with a possible resolution?
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Orbi/bd-p/Orbi
    Thank you.
  • FURRYe38's avatar
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
    I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
