salabate's avatar
salabate
Follower
Apr 28, 2021
ORBI RBR 50 won't connect to Google Home Mini's
I go through all the screens and it connects to the mini but as soon as I enter the wifi password it says it can't connect to the ORBI 50. There seems to be security from the router that blocks it at that point.
  • FURRYe38's avatar
    Netgear provides a simple mechanism to accomplish this:
    Log into the Orbi web interface (http://orbilogin.net)
    Navigate to the Advanced Tab, Advanced Settings, Wireless Settings
    Uncheck the box, "Broadcast SSID on 5G"
    Click "Apply"
    All devices that are currently connected to the Orbi will remain connected.
    On the smartphone, go to wireless settings and "forget" the Orbi SSID
    Search for available WiFi networks. Select the Orbi WiFi. Enter the password. and connect.
    If you are curious about whether the smartphone is actually connected at 2.4G, you have to wait a few minutes, because the "Attached Devices" display takes a while to update.
    Open the app and set up the 2.4G device.
    Once the device is connected and working as it should, reverse the steps.
    Check the "Broadcast" box and click "Apply"
    "Forget" the Orbi WiFi. Search. Enter password. Connect.
    Be aware that there seems to be a time limit with some iOS or Android devices that will connect to the 2.4Ghz radio for a short period of time before changing automatically to the 5Ghz SSID, even though it's been hidden. The SSID is hidden only, thus the signal is still present. So you might want to also change the power output of the 5Ghz radio to 25%. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
    If this fails, you'll need to contact Google about and ask for help and information regarding there product.
  • CrimpOn's avatar
    CrimpOn
    Hmmm. The Nest Mini that I bought at Home Depot connected first time using the Google Home app.
    It has been several months, so I do not remember exactly how it went. I have attached it to two different Orbii routers and do not recall any problems.
