mpage2
May 26, 2021Follower
Orbi RBR10
How can I temporaily turn off 5.0 in order to connect a 2.4 smart device?
Netgear provides a simple mechanism to accomplish this:
Log into the Orbi web interface (http://orbilogin.net)
Navigate to the Advanced Tab, Advanced Settings, Wireless Settings
Uncheck the box, "Broadcast SSID on 5G"
Click "Apply"
All devices that are currently connected to the Orbi will remain connected.
On the smartphone, go to wireless settings and "forget" the Orbi SSID
Search for available WiFi networks. Select the Orbi WiFi. Enter the password. and connect.
If you are curious about whether the smartphone is actually connected at 2.4G, you have to wait a few minutes, because the "Attached Devices" display takes a while to update.
Open the app and set up the 2.4G device.
Once the device is connected and working as it should, reverse the steps.
Check the "Broadcast" box and click "Apply"
"Forget" the Orbi WiFi. Search. Enter password. Connect.IF this is not seen on the 1 series Orbi, you might try changing the power output of the 5Ghz radio to 25%. Turn OFF The RBS. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. You may have to walk the device out to a distance to ensure it will connect to the stronger 2.4Ghz swignal After you get the IoT device connected, re-configure the system back to where it was.
mpage2 wrote:How can I temporaily turn off 5.0 in order to connect a 2.4 smart device?
The original Orbi models have an option in the web interface, Advanced Tab, Advanced Settings (at the bottom of the menu), Wireless Settings. (see attached image).
The "10" series are a diffrent product, and I am not confident that they have this same feature. (I don't have one, so I cannot check).
Perhaps it would be useful to know exactly which smart device this is. Manufacturers take great pains to warn customers IN BIG LETTERS, Must have 2.4G WiFi. If this were a TV remote and the package said, Must have 2 AA Batteries. no one would pay it any mind. C cells, D cells, and 9-volts will not fit (duh). Orbi systems provide 2.4G WiFi. The vast majority of products connect to Orbi systems They have no 5G radio chips in them, and thus cannot detect 5G WiFi signals. I have an entire box full of smart plugs, smart bulbs, security cameras, etc. my thermostat, bathroom scale, etc. that connected just fine.
Sorry for the rant. What is this device?
