GN100's avatar
GN100
Follower
May 18, 2020
ORBI RBR20 - download speed
Using the Netgear ORBI app on my iOS device it shows speedtest figures of approx 500Mbps down and up (I'm on a gigabit internet plan) ...... but running spped test by Ookla ..... shows no more than 70Mbps down and up ......... is this the capacity of the RBR20 (AC2200)? I thought it was much higher (867Mbps on 5GHz / 400 on 2.4GHz) ..... or is it that I'm abot 15m from the router (about 1m from the satellite) ...... which seems a massive drop off...
My desktop PC that is connected via wire is showing 200Mbps up and down
..... I'm confused!!
1 Reply
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
