Jo1234
Aug 19, 2020Follower
Orbi rbr20 : Firmware Check Error and router blocking our info to the router.
We cannot use our Orbi RBR 20 on our wired computer. The WiFi is working and we have a strong signal From our internet provider.
We are getting error messages
-that our calendar is connecting to a server that is pretending to be our calendar which could put our confidential info at risk.
- Safari cannot establish a secure connection
-NetGear is blocking our info in the router.
Our iPhones, IPads, etc are working. Hulu/Netflix in tv’s are not. iMac is having most issue with these error messages.
I tried to check if the Orbi had a firmware update and I received an error message that there was a “firmware check error”.
We are outside the support window on our product so Netgear cannot help.
Any advice? Thank you!
What firmware are you on with the orbi? And the satellites?
What modem/gateway are you connecting to?
Did this issue just occur or has this been going on since you set it up?
- MstrbigMaster
I doubt this has anything to do with the Orbi, unless you configured security.
What version of Safari are you using. It appears IOS13 has issues with Safari not establishing a secure connection on IOS13.
The 3 most popular methods for repairing this error on the Imac are:
- Open System Preferences and go to Network;
- Click Advanced;
- Navigate to the DNS tab and click + button;
- Enter 8.8.8.8 and hit Enter;
- Once again, click + button;
- Submit 8.8.4.4 and click Enter afterward;
- Hit Ok and Apply buttons.
- Open the site which shows Safari can't establish a secure connection error;
- Navigate to the address bar and click the (Lock icon) Secure button;
- Select More information;
- Click on View Certificate and check which certificate is in use;
- Go to Details tab and click Command + Space buttons at the same time;
- In the Spotlight Search enter Keychain;
- On the left panel select System Roots;
- Search for the website's certificate;
- Click on it and expand Trust section;
- On When using this certificate section select Always trust.
- Go to System Preferences;
- Open Network;
- Select Ethernet and click on Advanced button;
- Pick Manually on Configure IPv6;
- Hit Ok and click Apply.
