Nicolette730
Nov 08, 2022Initiate
Orbi rbr20 compatible satellites
I have an Orbi RBR20 router & 1 wall plug In satellite they work great but they seem to only cover 1/2 the house and I’m in need of another satellite but I can’t find anywhere what models of satellite are compatible with this router and the wall plug ones seem to be more expensive then buying and entire new system. Anyone able to help?
You can use:
RBS20, RBW30, RBS40,RBS40V, RBS50, RBS50Y
- Nicolette730InitiateThanks, I couldn’t find any of those at a reasonable price either I ended up buying an orbi router & 2 satellites for less money then one compatible satellite would have cost 😅
You do tend to find the kits renewed for cheaper than an individual satellite. Then you can either sell the router and make some $ back or use it as a backup in case the primary fails. 🙂
Glad you hear you got one though!
