kiwi69
Oct 28, 2025Aspirant
ORBI RBR20 Device Connectivity
Set up: Orbi RBR20 Router hard wired to Fibre connection Orbi Router hard wired to Orbi RBR20 Satelite #1 Satelite #2 connected wirelessly. Is there anyway I can stop devices trying to c...
CrimpOn
Oct 28, 2025Guru - Experienced User
Wired connections between router and satellite always provide better performance.
- WiFi connections are affected by distance and building materials. Cable is not.
- WiFi is inherently "half-duplex". i.e. only one radio can transmit at a time.
Ethernet is inherently "full-duplex". Traffic can flow in both directions at the same time.
- thomasjoe88Oct 29, 2025Aspirant
I appreciated this solution. I need also this guidance. One again Thanks
