Splnthgs1's avatar
Splnthgs1
Orbi RBR20 does not connect to internet through Draytek Vigor 130
Have just purchased RBR20 which worked patchily with BT HH6 so upgraded to Draytek Vigor 130. It is not not possible to connect to internet (BT) at all - any help you can give will be appreciated. ...
  • Splnthgs1's avatar
    Splnthgs1
    Mar 09, 2019
    Thanks all.  A little late night research showed that I hadn’t entered the bet internet password into the router!  Once I had done that all works well.
