Splnthgs1
Mar 08, 2019Aspirant
Orbi RBR20 does not connect to internet through Draytek Vigor 130
Have just purchased RBR20 which worked patchily with BT HH6 so upgraded to Draytek Vigor 130. It is not not possible to connect to internet (BT) at all - any help you can give will be appreciated.
- Mar 09, 2019
Thanks all. A little late night research showed that I hadn’t entered the bet internet password into the router! Once I had done that all works well.
michaelkenward
Mar 09, 2019Guru - Experienced User
Stephen
Is that this device?
If so, it looks like a straightforward modem, but I would check out the mode. Some modems, such as the Netgear DM200, have to be configured into modem only mode to work with a router.
Can you connect the modem to BT without the router in place?
If not, sort that out first. There's not much help that anyone from Netgear can give on that front.
Splnthgs1
Mar 09, 2019Aspirant
- FURRYe38Mar 09, 2019Guru - Experienced User
So the Modem is bridged?
Would be helpful if you gave feedback to the questions presented next time
Glad it's working now.
Enjoy. :smileywink:
- michaelkenwardMar 09, 2019Guru - Experienced User
Just one problem with that solution, BT does not need a password to login to its Internet. Just a username, which, from what I read, can be pretty well anything @btinternet.com. I use my BT email address.
- Splnthgs1Mar 09, 2019Aspirant
You are correct, of course, Michael - I meant to say user name where I used bthomehub@btinternet.com and this worked perfectly. Someone on a BT discussion thread said that they used the user name as password and this is what I did.
