Splnthgs1
Mar 08, 2019Aspirant
Orbi RBR20 does not connect to internet through Draytek Vigor 130
Have just purchased RBR20 which worked patchily with BT HH6 so upgraded to Draytek Vigor 130. It is not not possible to connect to internet (BT) at all - any help you can give will be appreciated.
- Mar 09, 2019
Thanks all. A little late night research showed that I hadn’t entered the bet internet password into the router! Once I had done that all works well.
Splnthgs1
Mar 09, 2019Aspirant
Mar 09, 2019Guru - Experienced User
So the Modem is bridged?
Would be helpful if you gave feedback to the questions presented next time
Glad it's working now.
Enjoy. :smileywink:
