Drbighead
Jul 17, 2019Tutor
ORBI RBR20 does not work WPS feature with Nighthawk X6 EX7700 extender.
I was very impressed by WPS feature with two wonderful gears (EX7700, RBR20) before updating recent firmware. After updating recent firmware of them, WPS feature is now no longer working. WPS featu...
Jul 17, 2019Guru - Experienced User
What Firmware is currently loaded on both devices?
What happens if you manually configure the EX to connect to the RBRs wifi SSID and PW?
- DrbigheadJul 17, 2019Tutor
RBR20 is now... ver 2.3.5.26
EX7700 is now...ver 1.0.0.188
After type SSID and PW, does not pops up the next page even in mobile app.
I am still trying to find out the last firmware worked properly...
- FURRYe38Jul 17, 2019Guru - Experienced User
Which unit was recently updated?
So logging into the EX with a wired PC and web browser fails to connect the EX to the SSID name and PW using it's setup wizard?
Both of them are updated.
Yep, I tried mobile app and wired PC both.
and also tried all of different security options of PW (AES,TKIP).
but, not worked still...
