RFRCEK961's avatar
RFRCEK961
Orbi RBR20 Doesn't Connect to Internet for WiFi for New Spectrum Modem
Spectrum said they are upgrading their equipment and sent a new HITRON E31N2V1 Modem. I connected the modem to the Orbi RBR20 and ran the ethernet from the Orbi to my desktop computer. I have 3 satellites on the Orbi with lots of devices: ADT Security, Ring Doorbell, Fire TV, Nintendo Switch, etc, and nothing works. I do have internet on the computer but no WiFi. The Orbi WiFi shows on my iPhone with 3 bars, but the Orbi App shows Internet Offline. I spent 90 minutes on the phone with Spectrum and they were unable to get it to work and said I should contact Netgear. I ran the New Setup on the Orbi App about 10 times with no luck. Please help.
    Did you just swap out one modem for another with the Orbi RBR20 router in place?
    If so, you may need to persuade the Orbi to forget any bad habits it picked up from the old modem. When you first set it up, it will have looked for things like the Mac address of your old modem. But that information is no longer relevant.
    Disconnect the Orbi, do a factory reset on it, and then go through the same setup process that you did when you first installed the RBR20.
    If you visit the support pages:
    Support | NETGEAR
    you can feed in your model number and find the documentation for your hardware.
  • michaelkenward's avatar
    michaelkenward
    Support | NETGEAR
    • RFRCEK961's avatar
      RFRCEK961
      Thanks. That worked. After wasting 2 hours on the phone with Spectrum and then purchasing a useless Netgear support contract and spending 2.5 hours on the phone with 3 reps and getting nothing accomplished, I saw your post, tried it, and all is well. Thank You.
