Degilio's avatar
Degilio
Orbi RBR20 drops wifi wired connection through it still works
I installed the RBR 20 to get mesh network connectivity replacing my nighthawk. At first it worked perfectly. Then after a couple of days it started to drop wifi every couple of minutes. Wired connections through the orbi still worked. I have no connectivity issues with the Nighthawk (even though there are some dead spots in the house with it (even with a range extender). I tried everything I could find on these forums to fix it but nothing seems to work. I understand that there is a fair amount of interference from neighbors houses but it doesn't seem to affect the Nighthawk.
Can someone explain to me why the ORBI is useless when Nighthawk works fine?
