orbiRBR20user
Apr 16, 2020Aspirant
Orbi RBR20 going offline
My RBR20 keeps going offline all the time.
The orbi is connected to homebroadband mobile router.
The orbi has a different SSiD from the ISP router because i had problems when making them the same.
I checked the lease obtained and it says 1 day is this the problem?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- orbiRBR20userAspirant
Thank you for the reply even though I must admit not understanding everything, since im a real pleb when it comes to networking and english isnt my naitive language. The ISP router is a huawei b818, my isp coustumer service said that it was in bridgemode as a standard but i have a suspicion he wouldnt know the up and down of a router.
You can check the status of the RBR and see if the modems is really bridged by logging into the RBRs web page at 192.168.1.1 in a web browser and navigate to Advanced tab. Look at the Internet Port section and find IP Address. If the modem is bridged, it should appear with two first and second set of numbers like this: ##.##.###.###. IF you see this similar number format. then the modem is bridge. If you see a 10 or 172 or a 192 address here, then the modem is not bridged.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
