HenryFitzgerald
Jul 14, 2019Aspirant
Orbi RBR20 internet speed lower than expected
I have a gigabit internet plan with my ISP (Actual max speeds: 950 Mbs download, 500 Mbs upload). When I connect my PC to my ONT directly via a cat. 6 ethernet cable, I enjoy the previously mentioned ...
doublepeak
Apr 15, 2020Aspirant
Any update on the issue? I also have the same issue. Any solutions?
HenryFitzgerald wrote:
I have a gigabit internet plan with my ISP (Actual max speeds: 950 Mbs download, 500 Mbs upload). When I connect my PC to my ONT directly via a cat. 6 ethernet cable, I enjoy the previously mentioned speeds.
Unfortunately when I plug my Orbi RBR20 into my ONT, speeds do not exceed 500 Mbs, both download and upload, when connected to the Orbi router via cat. 6 ethernet. Needless to say, speeds are lower when connected via Wi-Fi.
I understood the Orbi supported at least gigabit speeds. Am I missing a beat here? If so would be keen to know, thank you.
- FURRYe38Apr 16, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
doublepeak wrote:Any update on the issue? I also have the same issue. Any solutions?
- doublepeakApr 16, 2020AspirantI am using att fiber 1gb service. And modem is bgw210-700. I tried both ap and router mode and got pretty much same download speed of around 430mbps.
Thats over a wired connection?
Seem others post with this partciular modem.
https://community.netgear.com/t5/Orbi/ATT-fiber-BGW210-and-costco-RBR50-RBS50/m-p/1868313#M83488
https://www.f0il.com/how-to-arris-bgw210-700-modem-router-with-netgear-xr500-router/
ATT Dumb Swiith Method:
https://community.netgear.com/t5/Orbi-AX/Orbi-AX-6000-and-AT-amp-T-fiber-gateway-issue/m-p/1890125/highlight/true#M2756
Modem FW may have broke good speeds between the modem and Orbi in router mode:
