LARRYSTIT
Oct 22, 2019Tutor
Orbi RBR20 Keeps Rebooting
I recently bought and installed an Orbi RBR20 Router with 1 satellite, and updated to newest firmware v2.3.5.26 . It was working fine for about week. But now the router is randomly rebooting itse...
Amdahl
Jan 14, 2020Tutor
Similar Problem-
Brand new out the box Orbi RBR20 - keeps rebooting intermitently, the Router restarts. I did have a Wifi device that kept trying to connect(GE CONNECTPLUS WIFI MODULE) , have removed that and not seen this again (yet!).
Serial 5eh68c5e10dd0
Firmware - 2.3.5.26
- FURRYe38Jan 14, 2020Guru - Experienced User
Try a factory reset. Hold the reset button for 15 seconds the let go. Walk thru the set wizard with a wired PC.
What is the Mfr and model# of the ISP modem the RBR is connected too?
Please don't post the serial numbers of your Orbi systems.
Amdahl wrote:Similar Problem-
Firmware - 2.3.5.26
- TechieforhireFeb 19, 2020Aspirant
This product is about as frustrating as they come. I had the ISP set our cable modem to bridged mode so the Orbi could act as a router and the network stability was terrible. It was constantly dropping connections and resetting them. We decided to put the cable modem back into routed mode and use the Orbi as an AP. This was no better for wireless clients. We brought the Orbi upstairs to be closer to the Satellite and although it shows the status from the web interface (and app) as good with a good backhaul status the Orbi shows as purple connection status between it and the satellite.
Still wireless clients only stay connected to it for a maximum of two minutes however my laptop connected to the passthrough Ethernet connection CAN surf and stay connected so the issue is not with the Internet connection. I am not sure if there is something askew with its auto selection of 2.4 Ghz wireless channel that causes it to kick everyone when it decides to look for a less saturated channel constantly but suffice to say I have never had issues like this with any other wireless product including mesh offerings from other manufacturers.
- FURRYe38Feb 19, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerRBS wireless or wire connected to the RBR?
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Above suggestions working:
https://community.netgear.com/t5/Orbi/Throttling-Devices-RBK53/m-p/1858561/highlight/true#M81925
Be sure your modem routers wifi is disabled fully if it's in router mode.Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Be sure to read option #2...
Techieforhire wrote:This product is about as frustrating as they come. I had the ISP set our cable modem to bridged mode so the Orbi could act as a router and the network stability was terrible. It was constantly dropping connections and resetting them. We decided to put the cable modem back into routed mode and use the Orbi as an AP. This was no better for wireless clients. We brought the Orbi upstairs to be closer to the Satellite and although it shows the status from the web interface (and app) as good with a good backhaul status the Orbi shows as purple connection status between it and the satellite.
