jcg2026
Jun 24, 2026Aspirant
Orbi RBR20 static route issue
Is this the right group for the RBR20 router? I'm having an issue where I setup a bunch of static IP address (with MAC address) under Setup / LAN setup, and then under Security / Access Control I hav...
CrimpOn
Jun 24, 2026Guru - Experienced User
The title on this post is incorrect. Static Route refers to a router setting to direct connections to a specific IP range to a specific port. This is often used when the router is connected to a company network using a different internet connection. Using the LAN Setup to reserve specific IP addresses within the IP subnet for devices is called device reservation.
The first thing to check is that the device continues to present the same MAC address when it attempts to connect. Apple, Android, and many laptops now include a feature whereby devices present different MAC addresses under some circumstances. It is important to set the device not to do this when connecting to the home WiFi system.
CrimpOn wrote:The first thing to check is that the device continues to present the same MAC address when it attempts to connect. Apple, Android, and many laptops now include a feature whereby devices present different MAC addresses under some circumstances. It is important to set the device not to do this when connecting to the home WiFi system.
FWIW, Windows 10 and 11 laptops will randomize their MAC addresses when connected to "public" wifi networks. So maybe double-check that your Windows PCs have their network connections set to "private".
There are a couple of other similar scenarios to the one CrimpOn gave you.
One is that many devices (docked laptops, desktops, all-in-ones, printers,...) have more than one NIC (usually one ethernet and one wifi). Each NIC has its own MAC, so if a device connects using an interface you didn't expect it might be blocked.
Another is that WiFi extenders often will change the MAC address of the clients connected to them. This isn't very likely if you are already using an Orbi mesh, but if you are using a non-Orbi extender then it is possible that the blocked clients are connecting to the extender wifi.
What all these have in common: The blocked device will show a different MAC address from the entry in the static reservation.
jcg2026 wrote:then under Security / Access Control I have it set to turn on access control & Block all new devices from connecting.
Are you doing this for security? Or is there another purpose (like parental controls)?
I'm asking because while MAC addresses are often useful for device management purposes (like IP reservation), MAC filtering doesn't offer much (if any) extra security. One of many articles on the subject is here:
- https://smallstep.com/blog/mac-address-filtering-and-hiding-ssid-dont-work/
So if added security is your rationale, then I suggest just turning the MAC filtering off.
