missourimace
May 28, 2020Follower
Orbi RBR20 wifi drops in and out after update
I have had my RBR20 for a couple months. It seems to work fine but then the wifi just drops out and everything connected to it drops out. I had a trouble ticked but I didnt realize they had time limits on customer service. I started a new case. I updated the firmware to v2.5.1.16 even though when I asked the system said it was up to date. I connect my pc and updated manually. My internet just drops and then reconnects? I had charter/spectrum out today and they can find nothing wrong on their side. I drop in and out on voice conferance calls as well through goto and zoom so I have to dial in on my cell phone. Sorry just super frustrated with this wifi.
1 Reply
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
