jpress55's avatar
jpress55
Follower
Mar 20, 2020
Orbi RBR20 with 2 Satellites paired with Netgear CM400 Cable Modem - slow connectivity vs Linksys
Old setup:
Xfinity
NetGear CM400 Cable Modem
Linksys EA7500 Wifi Router (no sattelites)
Download Speeds consistantly around 150 MBps
Amazon Firesticks and Alexa devices working consistently on 5ghz
New Setup:
Xfinity
Orbi RBR20 Router and 2 Sattelites
Download Speeds consistently less than 5MBps
Amazon Firesticks and Alexa devices can't connect to 5ghz
Not sure what I'm doing wrong or if there is a different config setting I need to perform on Orbi router or on Netgear modem. ANy help would be greatly apreciated.
1 Reply
  • FURRYe38's avatar
    What is the Mfr and model# of the ethernet switch in the configuration?
    Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings. You can turn down the power on the 2.4Ghz radio as well to see if this helps direct devices to connect to 5ghz instead. It's up to them to connect to which frequency they choose too.
