RJGMarsden
May 06, 2020Follower
Orbi RBR20
Hi, I have purchased the above router and have been experiencing slow connection when using some Apps (Gmail, Drive, YT, Search). sometimes to get connection I turn the wifi off then back on agai...
May 08, 2020Guru - Experienced User
Modem Combo Units: https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-and-Cable-Modem/m-p/1864698#M21950
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
You may want to update FW as well:
