KenKY
Jan 11, 2018Aspirant
Orbi RBR40 - New Password Issue
I have a curious issue that I am not sure of the explaination or resolution. I recently got the RBR40 with satelite and I renamed the router name and changed the password. When I tried to logon to ...
- Jan 12, 2018
FYI- just did a chat with Netgear support. After trying a manual firmwear upgrade did not resolve it, I re-entered the same new password via the router login and re-applied it and that seemed to take care of the issue. Resolved!
DarrenM
Jan 12, 2018Sr. NETGEAR Moderator
Have you tried to remove the old SSID from the devices wireless settings?
DarrenM
- KenKYJan 12, 2018Aspirant
Hi Darren,
To clarify- it the same Orbi SSID that some devices take the new password I set and some devices did not take it but took the old Orbi password (with new Orbi SSID). It doesn't make any sense to me. I'm assuming then the original SSID and password was change the change is communicated to the satelite.
To review, let say the orginal SSID is ORBI123 and renamed it to ORBI345 and the original password was apple1234 and I renamed it to orange5678. The ORBI345 shows on all devices when I search networks, but a few devices will not accept the new password but the original password DOES work. So I have all devices connected to the same SSID but a few of them have different passwords. If I login to the router it correctly shows the new SSID and new password. Crazy!
