Uruk
Apr 27, 2018Tutor
Orbi RBR40 - Schedule not working
Hi, Since I updated the router firmware 2.0.0.56 to firmware 2.1.2.18, the schedule no longer works. Previously, it was configured to turn off every day at 00:30 and to turn on at 07:00. Since the...
- Apr 29, 2018
Thank you FURRYe38 for the link to this discussion.
My RBR40 system finally received yesterday (2018-04-28) a new automatic update to version V2.1.4.10.
The update alone did not correct the problem of the non-editable schedule. In addition, it was necessary to perform a factory reset for the calendar to be editable again.
Now everything is working properly.
Apr 27, 2018Guru - Experienced User
Get 40 series FW from here:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/td-p/1533584/page/29
- UrukApr 29, 2018Tutor
Now everything is working properly.- FURRYe38Apr 29, 2018Guru - Experienced User
Glad its working after the update. Enjoy.
