Orbi WiFi 7 RBE973
Reply
Orbi MR 2.1 Update 3/23/18
turns2stone
Apprentice
Re: Orbi MR 2.1 Update 3/23/18
@FURRYe38 wrote:
Can you post your switch model# again, I don't remember which one you had. Possible that this switch could be an issue. This is one reason for doing the long cable between the router and satellite.
Do you have more then one satellite that you can test with? You might swap satelites if you have more than one to test directly connection stability. It's possible that you have a bad Satellite and or bad router or system entirely aswell. If you can test with a different satellite directly to check stability. IF you seem to find that it's still not working well at this point, I would ask for a full RMA. Have them load up v2.1.3.4 and send a system out to you.
You would need to test the direct connect a bit longer if you have a long cable to see if the remote location exhibits the same 50% issue. Just seems that you are getting more results with direct connect then you not getting any connections with in wall cabling, switch and orinfrastrucure. This points to something in this area.
Main switch is D-Link DGS-1024D.
I spent several hours testing tonight, and I'm giving up - with this firmware, at least.
I do have two RBS50s to test with. Occasionally, I'll plug a LAN cable in, and the router GUI will still show 5G backhaul, this is even after 10+ minutes and a reboot. Sometimes I'll move a satellite to a completely different room/LAN drop, plug it in, and the LAN will crash, taking both RBS50s offline (magenta) as well as knocking out my RBS50Y.
Anytime plugging in (different) LAN cables in can knock out 2 other satellites, we're talking a serious firmware issue here.
Message 701 of 762
turns2stone
Apprentice
@OutGolfn wrote:
Wanted to note in this main thread the many issues with Apple HomeKit currently on V 2.1.3.4 and it’s very very bad with iHome Smart plugs. They are constantly switching from unavailable every few minutes.
I know another user Bill started a separate thread and hopefully Netgear has this Apple HomeKit issue fixed/addresses in the next update.
It was not an issue on any of the previous firmwares but V 2.1.3.4 has triggered it for many people with Apple HomeKit in their homes!
I have several HomeKit devices, including 3 outside, that would have a hard time staying connected. Then I got the RBS50Y, and now no more issues. I think these HomeKit devices just need a super-strong signal. If they lose Wi-Fi for even a second, it's like impossible for them to reconnect. So try moving a satellite closer?
Message 702 of 762
Guru
Maybe, maybe HW as well. Not everyone is having LAN backhaul issues. Even with managed switches, one user said he disabled IGMP protocol on the switch and is now working. I for one have a working LAN back haul system here with two non manged switches.
Your 1024D has the following features:
D-Link Green Features
• IEEE 802.3az Energy Efficient Ethernet (EEE)
• Link status detection power saving
Possible that this could be a factor as well. You would have to find a non managed swtich with out any of these features to testl. Both of my swtiches are just normal standard non managed switches with out any energy saving features.
So, v2.1.4.x seems to be looming soon. Why not give that a try and see how it does when it becomes available. I would go thru the motions of upgrading and doing a factory reset on both router and satellite to give it a good chance after insstallation. If it still exhibits the same problem after that, I think you'll need to ask NG for a RMA.
Up to you.
Message 703 of 762
Gelissen
The link on the first page of this topic for the RBS40 BETA MR 2.1.3 firmware doesn't work.
RBS40: http://files.netgear-support.com/go/?a=d&i=SoxDgoIHIg
Does anyone have the right link?
Thanks!
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only), RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only), RBS40| Orbi AC2200 Tri-band WiFi (Add-on Satellite), RBW30| Orbi Wall Plug Satellite
Message 704 of 762
wifi_en
Star
2.1.4.10 available through automatic update.
Message 705 of 762
Guru
Message 706 of 762
Guru
The 40 series files were removed for unknown reasons. You might contact NG support and ask for the v2.1.3.6 beta files if they will give them to you.
Thanks!
Message 707 of 762
Sdiver2489
Apprentice
I don't see anything yet when I go to the firmware update page. Figures too because I just rolled back to 2.1.2.18 yesterday
Message 708 of 762
Guru
Be advised there is newer v2.1.4.10 FW now for 50 series systems:
https://kb.netgear.com/000055985/RBR50-RBS50-Firmware-Version-2-1-4-10
Up to you if you wanna try it.
Message 709 of 762
adang2
Initiate
Could someone reupload the RBR40 and RBS40 firmware?
Message 710 of 762
Guru
You might contact NG support on the phone or ask @AmitR or @DarrenM in a PM.
Message 711 of 762
DarrenM
Sr. NETGEAR Moderator
I have fixed the links for the RBR40 and S.
DarrenM
Message 712 of 762
Guru
Thank you Sir.
DarrenM
Message 713 of 762
Guru
Message 714 of 762
adang2
Initiate
Thank you!!
Message 715 of 762
Guru
I recommend you factory reset both router and Satellite(s) after updating FW then set up from scratch.
Good Luck.
@adang2 wrote:
Thank you!!
Message 716 of 762
Gelissen
Thank you very much Smiley Happy
Message 717 of 762
loomis1975
Luminary
In related news, 2.1.3.4 was finally released for RBS50Y.
Is showing up in autoupgrade alongside 2.1.4 for RBR50/RBS50.
Or download at
https://kb.netgear.com/000056287/RBS50Y-Firmware-Version-2-1-3-4
Message 718 of 762
Ulairi
Luminary
Per this thread  the update to 2.1.4.10 reinstated a previous problem that I had with both wired and WiFi download connection speeds being throttled by the RBR50 Router.
I previously overcame this by a factory reset after the last manual update to 2.1.3.4..  I'm really annoyed that it seems that I now have to go through a factory reset and a full set-up all over again - to get the full connection speed.
Message 719 of 762
DJPedro
When I log into the Orbi app, the firmware update states that I have the latest firmware (2.1.2.18) - however when I log into routerlogin.net , a notification pops up that there is a firmware update!
Is this intentional, or is there an issue?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 720 of 762
Guru
You can download manually or use the web base router web page to update the FW. You'll be fine.
Message 721 of 762
khudsn7
Star
This is driving me nuts.  After spending many hours trying to find out why several of my home automation products(lifx lights, ring camera) suddenly stopped working...that is, stop connecting to the internet and after trying to reconnect them many times, without success, I have finally realized that this router updated itself(without my knowledge) to this new update.  They were all connecting just fine for many months and now, realizing this update went in around the time they stopped connecting, I suspect this update as something to do with it.  Has anyone else had this problem?  I have v2.1.4.10.  Can I reload the previous version?  How can I do that?  I used to have a full head of hair.  Now...not so much!
Ken
Message 722 of 762
khudsn7
Star
Same problem here.  Several of my home automation products stopped connecting after this update.  Need fix ASAP!!! How can I reverse this upgrade to previous version?
Message 723 of 762
Heliix
Guide
I did not pay $525 for a WiFi system to be NETGEARS beta testers!!!!
Give us the ability to disable auto upates..
2 updates 2 bricks..
please stop by to sign the petition to give us the abiltiy to disable auto updates
https://community.netgear.com/t5/Orbi/Petition-to-disable-auto-updates/m-p/1561982#M29828
Message 724 of 762
tagteam
Virtuoso
Message 725 of 762
Top Contributors
Announcements
Orbi WiFi 7
