GreenNinja
Feb 11, 2018Aspirant
Orbi RBR40 and FIOS Question
I set up the Orbi with my Verizon network per the instructions on this forum (i.e., I turned off the Verizon Fios wireless network and then set up the Orbi router in AP mode.) I have internet, TV an...
Roamabout
Feb 11, 2018Luminary
It sounds like the wifi on the Verizon router did not get turned off if you can still see it and connect to it. Double check that it is disabled in the router config and if you still see the ssid being broadcast reboot the verizon router.
GreenNinja
Feb 12, 2018Aspirant
Thanks to you both for your responses. I checked that the WiFi access was turned off on the Fios modem/router and the network is still showing up as available even after rebooting the Verizon WiFi modem/router.
