GreenNinja
Feb 11, 2018Aspirant
Orbi RBR40 and FIOS Question
I set up the Orbi with my Verizon network per the instructions on this forum (i.e., I turned off the Verizon Fios wireless network and then set up the Orbi router in AP mode.) I have internet, TV an...
Roamabout
Feb 12, 2018Luminary
If you have truly disabled the wifi on the Verizon router you should not be seeing it as an option to connect to. Are you sure it is not one of your neighbors ?
GreenNinja
Feb 12, 2018Aspirant
I believe I've figured it out.. we had a network extender that was still plugged-in and that was making the network available.. once I unplugged the extender the option to join the network on through the Verizon router was unavailable. Thanks for your help with this.
