mscleare
Apr 18, 2019Follower
Orbi RBR40 router - 2 on 1 network?
I bought an Orbi Kit with the RBR40 router and 2 R BW20 satellites. It worked fine until I moved to a much bigger house with an outside area that needs coverage. I have access to a similar kit (only 1...
Apr 18, 2019Guru - Experienced User
No, the RBRs only work in router or AP modes. They do not work as satellites.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
